PC resevoir level indicator
Indicate the liquid level inside PC liquid cooling resevoir
Using a pressure sensor to measure the liquid level inside PC liquid cooling resevoir, or any liquid container such as fish tank or green house / plant feeder.
RGB LED strip to indicate level through both level and colour of the output
And to allow simple calibration of the zero level and indicated level, via the use of a pair of variable resistors.
A simple pressure sensor based liquid resevoir level indicator for use on PC cooling, or any other liquid level monitoring. Uses USB 5V power to runa and has ATTINY programming and auxilliary pin, and SPI pins exposed for expanding  / linking to other systems.
Level_indicator.STEP
3D CAD
step - 1.91 MB - 05/12/2020 at 13:44
Download
level_sensor.pro
KiCad
pro - 4.38 kB - 05/12/2020 at 13:43
Download
level_sensor.kicad_pcb
KiCad
kicad_pcb - 90.64 kB - 05/12/2020 at 13:43
Download
level_sensor-cache.lib
KiCad
lib - 6.59 kB - 05/12/2020 at 13:43
Download
level_sensor.sch
KiCad
sch - 9.63 kB - 05/12/2020 at 13:43
Download
  • 1 × ATTINY816
  • 1 × 1551MFL Boxes, Cabinets, Enclosures and Racks / Boxes
  • 1 × WS2812B LED strip
  • 1 × MPXV4006GP Sensors / Pressure, Force
  • 3 × 0.1uF - 0603 capacitor
View all 11 components
  • PC resevoir level indicator overview
    David Brown05/24/2020 at 17:21 0 comments
    1. Assembled board, 1 pot for adjusting zero level and one for adjusting the measured / current level
    2. Showing the pressure sensor
    3. In the case
    4. Outside, with pressure tube fitted
    5. Assembled cables and LED strip
    6. Uncalibrated, negative need to set the zero level pressure
    7. Zero level pressure set
    8. Resevoir with tube passed in from the top so the open end is at the bottom of the container. Because the static pressure is constant everywhere in the tube, the pressure measured at the sensor is the pressure at the open end - at the bottom of the water column.
    9. Adjust the 'high' level pot so that the LEDs match the level in the resevoir
    10. Assembled back into the case. Many options here for setting up the LEDs if you have a window case.
View project log
Rich text editor
