I decided to just reverse the entire board. Less error prone that way. I've got all the IC footprints on the board, most of the resistors and capacitors, and most of the filled zones.
This is testing my patience.
A project log for Reviving and Reverse Engineering an Old Robot Arm
A full reverse engineering and rebuild of a Mitsubishi Movemaster robotic arm
