Encoders Working
A project log for Drumming robot
MIDI drum machine to complement live electronic music
valVal • 04/15/2021 at 20:19•0 Comments
I finally got chained ADS1115 encoders working to read arm bone positions. It was really confusing because the manual lists configuration setting bit offsets in low-endian, but the chip then accepts the resulting bytes in high-endian (reverse) order. Code here:
https://github.com/01binary/drummingrobot/blob/master/src/code/ads1115.cpp
The breakthrough came after I took the Raspberry Pi with me hiking and stayed at a countryside hostel for the night, debugging into late hours
