Evolution...
A project log for aStrA : Aligned Strings format with attributes
Developing a more flexible pointer and structure format that solves POSIX and Cs historical problems.
yann-guidon-ygdesYann Guidon / YGDES 01/09/2023 at 18:150 Comments
Progress is strong these days.
I shuffled things around : types 0 and 3 are swapped so optimised code can more easily read the size of lists.
The Flexible strings are also adapted a bit.
The whole thing is now defined as a "descriptor" or "handler" type, called aStr_t and declared in C as uintptr_t
As a result we get this new map :
Type F0 is undefined and should be congruent with type 0 "points".
I uploaded the latest aligned_strings.h here.
I now move on to implement the required support functions.
