The aligned format is great, while it remains used inside a safe and controlled context.
It can get ugly though when an "aligned string" pointer is transmitted through an untrusted piece of code. This unsafe code could be prevented from dereferencing the string's value but this is not enough. If the pointer itself is modified, all kinds of problems arise.
Receiving a pointer to an aligned string from a dubious source can be less dangerous if the type is restricted. The type 2 (16-bit length) is the safest and it's easy to filter. The Type 3 creates indirect (de)references and the flexible types should be cast back to constant strings (it might not be possible to modify or reallocate the target anyway).
Use Type 2.
