Prototype board, plus Breadboard area, plus holes to mount the FINE DUST. PM 2.5 & PM 10
MODULE SDS011
This board (without the SDS011) will be used as the bottom board in the RASPBERRY frame.
A project log for M10CUBE
M10CUBE (M10 in short) is a modular controller box with cube dimensions 10x10x10cm. Raspberry bus will be used for the first incarnation.
MODULE SDS011
