m10sensor is undergoing LoRa first tests. A problem fount on some tracks connecting NSS and SCK pins from E22-900M22S LoRa chip to SS_LORA and SCK_ESP pins of ESP32.
So that you see is the result of the test. The brilliant library used is made by the excellent engineer Stuart Robinson.
https://stuartsprojects.github.io/
https://github.com/StuartsProjects/SX126X
As soon tests completed and all subsystems go I will publish the total firmware.
![](https://cdn.hackaday.io/images/4870311610361989000.jpg)
