KiCAD6. This is an OUTPUT 8XRELAY 10A module name M10DO01-10. I2C interface and Raspberry bus. All modules from version 10 and later are sharing the new 90x90mm PCB.
Sent for PCB fabrication in JLCPCB.
![](https://cdn.hackaday.io/images/4293111641486549403.jpg)
https://drive.google.com/file/d/19BHYOpB_LdBVpj1kuEgSROXb5tUBSk9Q/view?usp=sharing
