M10CUBE NUCLEO64 CNC
A project log for M10CUBE
M10CUBE (M10 in short) is a modular controller box with cube dimensions 10x10x10cm. Raspberry bus will be used for the first incarnation.
vasilis-vorriasVASILIS VORRIAS 01/06/2022 at 19:130 Comments
KiCAD6. M10NC01-10 was designed using / CNC_Breakout_Nucleo64 exact design and ported to M10CUBE platform.  Is using GRBLHAL software https://github.com/grblHAL
All modules from version 10 and later are sharing the new 90x90mm PCB.
Sent for PCB fabrication in JLCPCB.
https://drive.google.com/file/d/1lqcJAB9dWVi5FL99OL5zKJ2o9BPOuXyq/view?usp=sharing
Rich text editor
