We received from JLCBC a batch of PCB concerning previews designs.
1 - M10CUBE NUCLEO64 CNC. PCB code M10NC01-10
https://hackaday.io/project/171770-m10cube/log/202097-m10cube-nucleo64-cnc
2 - M10CUBE I2C INPUT 8X24V, OUTPUT 8XSSR TRIAC. PCB code M10DX02-10
https://hackaday.io/project/171770-m10cube/log/202093-m10cube-i2c-input-8x24v-output-8xssr-triac
3 - M10CUBE I2C 8XRELAY MODULE. PCB code M10DO01-10
https://hackaday.io/project/171770-m10cube/log/202092-m10cube-i2c-8xrelay-module
4 M10CUBE PROTOTYPE. PCB code M10PR04-10
When populated and tested we will post the results. If all gone well, KiCAD6 designs will be published.
Meanwhile as already announced we are preparing new I/O designs with Raspberry Pico on board in place of MC23XXX chips. That is necessary to line up M10CUBE concept with the era of Edge computing in IOT market.
