All five PCB types arrived some days ago. I Started building the M10CUBE system and checking for errors.
Then trying to fix the fitting inside frames.
From first impressions only minor problems. Will be fixed on the next version.
Soon test results will be published.
First version of the sensor board firmware is written and sends data to the influx and grafana running on the Raspberry .
I will publish the firmware as soon as testing is OK.
If you need any info please ask. I will be happy to provide.
