Okay, so the prints are printed and the switches are lubed and re-sprung. Time to do the real work of turning it into a keyboard. But I'm not ready! So what needs to happen now?
- To glue or not to glue? Most of the switches snap in and stay put. A few of them come out way too easily when the keycap is removed. I'm tempted to glue them all in place, maybe a lil dot in all four corners under the top housing.
- But I should really test all the switches first. I haven't done that because I wanted to make a little testing rig so I can just plug in a switch and make sure it lights an LED or something. But man, those switch pins are weird. They only fit in female header at an angle, but you can't angle header into a protoboard. Last night I tried to make a tester with copper tape and a cardboard box.
- And really, I should probably wire a small practice matrix first. At least 3x3, but the bigger, the better.
I will tell you this: I have wanted automatic wire strippers for a long time, and I finally got some. They excel at stripping wire in the middle so you can wire up your switches like this instead of cutting a bunch of short wires. NOTE: the picture below is someone else's build.
kristina panos
Oh, you re-printed your upper case, and changed switches. I've printed mine and I'm almost exactly at half a spool of filament. My mentor was a huge proponent of foam-core and copper tape circuits.
Case is the same, it just looks different in every light! I did switch to browns because I think I will really like this keeb and want to be able to use it a lot.
Edit: oh, I get it. The one above is just a wiring example I found. I was trying to illustrate the benefits of a single wire with a peekaboo stripping job!
Oh you should have said about the tester - that's exactly what a Kailh hotswap socket would excel at. Perhaps it wouldn't have arrived fast enough for you and your copper tape hack sounds like a good workaround.
Oof, you are so right! >_<
I was just about to buy a pack of them and play the waiting game when I got a bit of inspiration. :D
Job done!
Diy keyboards seem like a classic among the rabbit holes of "build the tool before you can build the thing" but they get away with it because they're so useful!
