Command line tools
Installation
sudo apt install alsa-utils
Audio playback
We want to route audio to the line-out. In order to do that, let's find out what the possible output devices are.
ubuntu@wandboard:~$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default:CARD=DWHDMI
DW-HDMI, dw-hdmi-ahb-audio
Default Audio Device
sysdefault:CARD=DWHDMI
dmix:CARD=DWHDMI,DEV=0
Direct sample mixing device
dsnoop:CARD=DWHDMI,DEV=0
Direct sample snooping device
hw:CARD=DWHDMI,DEV=0
Direct hardware device without any conversions
plughw:CARD=DWHDMI,DEV=0
Hardware device with all software conversions
usbstream:CARD=DWHDMI
DW-HDMI
USB Stream Output
default:CARD=imxspdif
imx-spdif, S/PDIF PCM snd-soc-dummy-dai-0
sysdefault:CARD=imxspdif
dmix:CARD=imxspdif,DEV=0
dsnoop:CARD=imxspdif,DEV=0
hw:CARD=imxspdif,DEV=0
plughw:CARD=imxspdif,DEV=0
usbstream:CARD=imxspdif
imx-spdif
USB Stream Output
default:CARD=imx6wandboardsg
imx6-wandboard-sgtl5000, HiFi sgtl5000-0
sysdefault:CARD=imx6wandboardsg
dmix:CARD=imx6wandboardsg,DEV=0
dsnoop:CARD=imx6wandboardsg,DEV=0
hw:CARD=imx6wandboardsg,DEV=0
plughw:CARD=imx6wandboardsg,DEV=0
usbstream:CARD=imx6wandboardsg
USB Stream Output
Mixer settings
- Run "alsamixer"
- F6: select sound card → imx6-wandboard-sgtl5000
- Headphone Mux : DAC
- Use "Headphon" to set audio output level on line-out. The line-out setting in alsamixer doesn't control line-out.
Storing sound settings with "alsactl store" gives an error message.
Let's play a wav-file now using hw:CARD=imx6wandboardsg,DEV=0 if we would use plughw:CARD=imx6wandboardsg,DEV=0 ve9qrp.wav, then the mono audio from the file will be sent only to the left or right channel of line-out.
ubuntu@wandboard:~$ aplay -D hw:CARD=imx6wandboardsg,DEV=0 ve9qrp.wav
Playing WAVE 've9qrp.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
The mono-wav file will be output to the left and right channel of line-out.
Audio recording
By default audio will be recorded from MIC_IN. To record from LINE_IN, the capture multiplexer (mux) must first be adjusted:
ubuntu@wandboard:~$ amixer -c 2 cset name='Capture Mux' 1
numid=24,iface=MIXER,name='Capture Mux'
; type=ENUMERATED,access=rw------,values=1,items=2
; Item #0 'MIC_IN'
; Item #1 'LINE_IN'
: values=1
After that, recording 5s of audio from line-in is as simple as:
ubuntu@wandboard:~$ arecord -D default:CARD=imx6wandboardsg -d 5 -f S16_LE -c 2 -r 48000 output.wav
Recording WAVE 'output.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
