Some of the major updates in the firmware... (more to come) V1.35: - Fixed PID calculator coefficients and sampling (it could have had oscillations) - PID tested with 12V in and duty 110-220 with low and high resistance cable, acceptable performance in all cases - Missing to correct refresh rate of the screen (it is increased as the main loop is executed more times) V1.4: - Added channel tracking option in menu. Now it is possible to set one channel temperature, and both are set. V1.5: - Added AutoON function in menu: When changing tip, the channel goes on automatically to the set temperature. V1.6: - Buttons very responsive, including encoder switch - Some code cleanup
Riccardo Pittini
