First test of the Sentry watergun, now with water and moving targets :)
Still some room for improvement, the movement is still a bit slow, also some elastic effect in the belts of the x-axis. The belts will be replaced by chains, also the stepper speed will be increased significant in next update.
But even with the current setup, there is already a lot of fun :)
