Today I succesfully mounted the Nema 23 motor, everything worked as expected :)
Next step is mounting everything back together for first test and see if force has been improved over the Nema 17 with 6mm belt:
A project log for Sentry water gun (lidar tracking!)
This high tech water gun will track persons with the lidar sensor and fire several shots of water
