I needed to trip is down and pull out the reflector which was pretty easy. Here above I have is painted gray.
A project log for Field Ready-TRIO UV 365-395nm Curing Light
3 watt White LED, 9 watts 365nm UV and 9 watts 395nm UV. All in one tool built for Field Ready use.
