This was the first try for printing a ring, the ring was far too tight and after the test fit I could not pull it off and had to destroy it.
A project log for Field Ready-TRIO UV 365-395nm Curing Light
3 watt White LED, 9 watts 365nm UV and 9 watts 395nm UV. All in one tool built for Field Ready use.
