Last year was tough but also productive. Several of my friends had joined the Zakhar team and we will try to build a real product.
We've come up with the idea of creating a pet companion! Dogs and cats only for now 🐶😺. (Check the updated project description). We will be moving towards this idea and the project will remain open-source, so even when we finish you will be able to build your own companion from sources!
There are a lot of things that should be done here and we going to entertain you with our test videos. For now, check out the ears that I 3D printed for the robot!
Andrei Gramakov
