Now after some polishing of the basic emotional core I can tell about how it works and about it's structure.
Emotional core consists of three main parts (see the picture bellow):
- Input Data Descriptors - describes data from sensors and how it should affect the core
- Emotional States Descriptors - named states of the core described by specific values of core parameters
- Core State - contains core parameters, value of sensors and pointer to relevant to parameters Emotional States Descriptors
Or more detailed:
When you write the data, the core does the following:
- updates saved sensor value
- updates core parameter: param += (new_sens_val - old_sens_val) * weight
- updates the current core state based on updated parameters
Here are some examples of data that could be used with the core.
Example of core parameters:
[ "cortisol",
"dopamine",
"adrenaline",
"serotonin" ]
Example of a core's emotional state:
"name": happiness,
"conditions": [
"param": "cortisol",
"op": LESS_THAN,
"value": 10
"param": "serotonin",
"op": GREATER_THAN,
"value": 100
Example of input data descriptor:
"sensor_name": "temperature sensor",
"val_min": 0,
"val_max": 255,
"weights": [
"core_param_name": "serotonin",
"weight": 0.5
"core_param_name": "cortisol",
"weight": -0.5
Input data example:
"value": 120
My next step will be in looking appropriate parameters and weights that can adequately describe (roughly of course) some human emotions.
Source core: https://github.com/an-dr/r_giskard
Andrei Gramakov
