I am thinking along these lines for a brake caliper actuated by a servo.
Jaws will be pushed apart by a spring. They will be pulled together by cables attached to each jaw and going through the center of the base. Jaw ends will have 2x8x14 mm slices of pencil eraser glued to it.
