Most Parts on Order, Piezo Diaphragms Received
06/07/2020 at 15:45 • 0 commentsMost of the parts are on order from Aliexpress and should arrive in 30 to 50 days. In the meantime, I will be developing and testing the active band pass filter and envelope detector circuits. I also received ten 35mm piezo diaphragms this week. I will be using them to create several DIY hydrophones so I can start taking underwater audio recordings of boats.
System Architecture, First Iteration
06/01/2020 at 02:43 • 0 commentsThe first iteration of the BoatDetect system architecture is complete. The device is mounted underwater and tethered to the bottom. A piezoelectric diaphragm senses the noise generated by boats passing by overhead. An active low pass filter removes all frequencies above 1000Hz and amplifies the signal. An envelope detector outputs a positive peak amplitude signal. The Tiny85 microcontroller periodically reads the analog signal. If the voltage of the signal is above the detection threshold, the Tiny85 wakes up the Arduino Nano. The Nano writes a timestamp to a file on the SD card and goes back into power down mode. The Tiny85 continues to wake up the Nano every time the voltage signal is above the detection threshold. The Tiny85 stops waking up the Nano after about four weeks when the battery state of charge drops below 10%. At this point, the device has to be retrieved for service. The data file is downloaded from the SD card and the batteries are removed and replaced with a fully charged set. A quick analysis of the data will show hours of the day and days of the week when boat traffic is heaviest in the vicinity of the device.
Total estimated cost of the system is approximately $37. The cost breakdown by component is detailed in pie chart below. Almost 50% of the cost is in the batteries and water bottle.
Low-cost Hydrophone
05/28/2020 at 05:11 • 0 commentsThe first challenge of this project is development of a low cost hydrophone. Fortunately most of the legwork has already been done for me. Governments have funded research on vessel fundamental frequencies, weekend hackers have developed and tested several DIY piezio diaphragm hydrophone designs, and a couple researchers even developed a frequency response curve for a common DIY hydrophone build.
According to a paper titled "Acoustic surveillance of small surface vessels in confined areas" by A. Tesei et. al of the NATO Undersea Research Center in Italy, the fundamental frequency and source level of 7m outboard motor and fishing boats range from 0.25 to 1 kHz and 150 to 156 dB re 1uPa @ 1m respectively.
You can find dozens of DIY piezio diaphragm hydrophone builds online, but this one , do-it-yourself hydrophones, by John Grzinich in Istanbul even includes a sound recording of motor boats.
Over to the west side of the Atlantic, two researchers Eduardo Vivas and Braulio Lopez submitted a paper titled "Construction, calibration, and field test of a home-made, low-cost hydrophone for cetacean acoustic research." to the Acoustical Society of America. The paper details a frequency response curve of a DIY hydrophone. The frequency response curve starts from -55 dB re 1 V/uPa near 600Hz and continues upward to -25 db re 1 V/uPa at 8kHz. So capturing lower frequencies down to 250 Hz that are characteristic of fishing boats may be a challenge, but otherwise its still worth getting some parts on order and building one myself to test.
