A simple circuit that blinks out the genome sequence of Covid-19
It blinks out the genome code for COVID-19. The 4 LEDs are for each nucleotide, Adenine, Thymine, Guanine, and Cytosine. They blink in order, and the 7-segment display also shows the letter for each nucleotide. Each nucleotide is shown for about half a second.
Bad luck on the hard drive mishap. Best of luck getting back to normal. Keen to see the code when you do.
Thanks man, I don't know if I will ever have the motivation to re-write the code but if I do I'll post it here asap!
How does it work exactly?
