Success!
Both speakers printed. They sounded pretty good without any equalisation, though around 10 kHz there's a little more harshness than desired. But that's nothing to do with the transmission lines. It's the drivers themselves. Below is a set of plots of the response curves:
The blue plot has much better flatness than the original speakers. A little ironing with Eaualizer APO and they're great. I did attempt to meddle with the crossover, but that can of worms requires swapping in and out lots of capacitors and inductors. Using a DSP is much easier. Besides, the crossover had correct phasing, any meddling could have crippled that.
Now to draw up and print some stands and I'm done.
