Dronecoria: Drone for Aerial Reforestation
Open source drone platform for aerial sowing of seed balls, for a revolutionary and efficient, automatic reforestation.
Public Chat
Dronecoria (Dronechory) is a collection of tools for a revolutionary ecological restoration with drones, for aerial seeding of seedballs with efficient microorganisms, to make green large-scale landscapes at low cost. Dronecoria makes easier the restoration at industrial level, sowing a combination of millions of trees and herbaceous for carbon fixation, with the power of open-source, digital fabrication, and a worldwide community of ecologists.
Dronecoria represents a new area of symbiotic species, produced by biological and technological processes, revealing the potential impact of interaction between ecologies and robotic systems on critical environments. Relies on mechanisms borrowed from cybernetics, robotics and permaculture, to sow seeds from affordable wooden made drones. Allowing accurately positioning of each new seedling, eliminating the competition, and increasing the chance of survival.
Drone technology combined with native coated seeds will revolutionize the efficiency of ecosystem restoration. We created a set of open sourcetools, to use drones for sowing seedballs of wild seeds with efficient microorganisms for ecological restoration,making easier the seeding at industrial scale and low cost.
Drones can analyze the terrain and sow with precision hectares in minutes. Sowing a combination of thousands of trees and herbaceous for carbon fixation, turning every seed into a winner, making green large-scale landscapes at low cost, with the power of open-source and digital fabrication.
We share this technology to individuals, ecologist teams and restoration organizationsaround the world, for dramatically improve the traditional forest seeding.
Dronecoria represents a new area of symbiotic devices, produced by biological and technological processes, revealing the potential impact of interaction between ecologies and robotic systems on critical environments. Relies on mechanisms borrowed from cybernetics, robotics and permaculture, to sow seeds from affordable wooden made drones. Allowing accurately positioning of each new seedling, increasing the chance of survival.
Specs:
  • Total weight without payload: 9,7Kg.
  • Flying time without payload: 41min.
  • Maximum payload: 10kg of seeds.
  • Autonomy: Can sow in autopilot one hectare in 10 minutes, around 5 seeds by square meter, with a speed of 5 m/s.
  • Production cost: 1961,75 US$
License:
All files are licensed with Creative Commons BY-SA, this perfectly allow to make profit with this project (please do it!) You only are required to give us attribution (dronecoria.org), and if you made any improvement, you should share it with the same license.
dronecoria_6mm_v0_6_4.AI
Dronecoria Frame Version 6 Adobe Illustrator files to send to the laser cut.
postscript - 454.71 kB - 05/29/2020 at 18:15
Download
SeedShutter.stl
Shutter of the bottle to open/close and adjust the seed flow. STL files to 3D print
Standard Tesselated Geometry - 8.40 MB - 05/29/2020 at 18:18
Download
SeedDisperser.stl
Disperser to spread the seeds STL files to 3D print
Standard Tesselated Geometry - 4.37 MB - 05/29/2020 at 18:18
Download
dronecoria_6mm_v0_6_4.dxf
Dronecoria Frame Version 6 DXF files
AutoCAD DXF - 5.48 MB - 05/29/2020 at 18:14
Download
  • 6 × Propellers T-MOTOR Polymer Folding 22" MF2211
  • 6 × Motors T-Motor P60
  • 6 × ESC's Flame 60 Amp
  • 2 × Battery Tattu Plus 12000mAh 22.2V 15C 6S1P Lipo Battery
  • 1 × Flightboard HolyBro Pixhawk 4 & M8N GPS Module Combo
View all 9 components
  • 1
    Part Identification
  • 2
    Mount upper part
  • 3
    Mount lower part of the arms
View all 6 instructions
Sasuke Uchiha wrote 04/03/2023 at 20:38 • point
Cannabis seeds come in three varieties: normal, feminised, and autoflowering. https://justcannabisseed.com/free-cannabis-seeds-with-every-order/
Josh Starnes wrote 09/04/2020 at 23:48 • point
how much does that wood frame weight?
Brian McEvoy wrote 08/23/2020 at 16:58 • point
Where does the name come from?
What kind of plywood do you use?
Leonardo Leoni wrote 05/29/2020 at 22:47 • point
very nice, you could put it in production, it could be a commercial product
Aeracoop wrote 05/29/2020 at 18:28 • point
Hi! We are the team of dronecoria!
Please send us any comments here.
