Analog FM demodulation, and modulation, is a unique and officially supported special feature of this transceiver. ON Semiconductor even provides an application note on how to set up and use the transceiver as an analog FM transceiver, "AX5043 Use as Analog FM Transceiver". Both the application note and the configuration used are for Wideband FM signals, the type used in FM Radio Broadcast. FM Radio Broadcasts were actually used to test the FM demodulation with good success!
As with the AM Demodulation, the basis of the FM Demodulation is the internal DAC. For FM Demodulation the DAC is setup to output the Frequency Tracking value. With the transceiver setup properly, the FM signal is first down-converted into the IF stage where the frequency change over time is tracked and output by the DAC. This tracking information is also accessible over the SPI interface of the transceiver.
To show the FM modulation in the IF stage, the DAC was configured to output the SAMPLE_ROT_I (or SAMPLE_ROT_Q) and a RF signal generator connected to the module is used to generate the FM signal, using as the modulating source a pure 500 Hz tone. In the figure bellow the FM signal in the IF stage is shown in blue and the pure 500 Hz tone is shown in yellow.
With the DAC setup to output the frequency tracking value, the FM demodulation, the signal observed is shown in the figure bellow. In blue is the FM demodulated signal and in yellow the original audio signal used as the modulation source.
As with the AM demodulation, a lot of noise is visible on the demodulated signal. This noise is also very clearly audible in the audio output of the module, through the audio jack. The main source of this noise is from the not well filtered DAC output.
Samples of the output audio can be listened to on my website, as well as all the configurations used to achieve the FM demodulation.
A little teaser on what I'm testing and working on for this project can be seen on my twitter, very early stages still.
NotBlackMagic
Looking for a way to stay up to date on the latest news, music, and sports? Look no further than https://radiofmluisteren.nl/, the ultimate online radio destination. With over 100 different stations to choose from, there's something for everyone.
Get your day started with a cup of coffee and the latest news on your favorite station. Then, rock out to your favorite tunes as you finish up that work project. And when you need a break from work, catch up on the scores of your favorite sports teams.
Whether you're at home or on the go, Radiofmluisteren has you covered. So tune in today and start listening to the best radio has to offer!
