RESQ:
I was inspired by the constant stream of search and rescue operations on the television show "North Woods Law". Each week they struggled to find lost people in the remote/rugged areas of Maine U.S.A. These areas often have no cellular service but in almost every case the target people had cellphones on them and working. As I live in Canada- we have a surplus of these situations in our vast wilderness as well. I theorized I could use an external 2.4GHz antenna to receive the beacon frames from those phones ad capture that data and locate persons of interest.
This hardware can be embedded in to any very small drone or RC aircraft. It can also be attached to existing manned aircraft already participating in the search. It can even be monitored live via Bluetooth on your phone or tablet from inside the aircraft cockpit!
Using small drone aircraft (like the Nano Talon I use here) gives all the advantages such as flight condition tolerance, height, terrain, time of day etc that drones have over manned aircraft. They can also be sent on the full way-point mission without human intervention and tracked live from any ground station.
What ResQ does:
- Detects all Beacons, their RSSI and their MAC addresses
- Detects All Access Points (APs) in range -not needed but I log them anyhow
- Gets GPS Lat/Long position
- Gets GPS UTC Time
- Logs all the above to the SD card .csv file every time any new target is detected
- Displays the number of clients detected, APs detected, time and Lat/Long on the OLED screen live.
- Triggers the camera module to capture an image of the area (optional)
- Sends the target info to your phone/tablet over Bluetooth (optional)
- Sends data to remote monitoring station via LORA (under final dev currently)
COMMERCIAL OPTIONS
I have only found this one unit which does a similar task but is handheld only, limited to ~150 feet range and retails for $2400 USD. Our ResQ project has similar functionality (using 2.4 GHz) for only a small fraction of this cost. Our air unit is also easily deployed by aircraft or drone. Nice.
BUILD
The air and ground units both use exactly the same hardware/PCB with the only difference being the power supply on the ground (battery) and larger directional antenna on the ground unit. This keeps the instructions, assembly and BOM very simple. All the parts (except YAGI) are currently even stocked in my local Amazon warehouse here in Canada - Handy!
I am using the Wemos D1 mini PRO ESP8266 (for both air and ground units) with an external antenna (YAGI or omni/dipole) to receive the beacon frames, log them to SD Card with the MAC address and GPS coordinates to easily plot with Google Earth/maps. It can also transmit the live data telemetry via LORA or similar module to the ground instantly as well by sending the debug UART via radio to a simple USB interfaced ground station.
The electronics are simple enough that anyone with basic soldering skills can assemble their own ResQ from scratch or kit in under an hour.
V3 of the PCB/project will be entirely discreet components and open the door to possibly producing these units at scale for a lower price and MUCH smaller package.
MEDIA
Contest Entry Overview Video:
Build Part:1
Build Part 2:
Build Part 3:
Part 4:
See YT playlist for existing tutorials in the links (I documented most facets of the build in standalone related videos which when all combines- make this project) Handy eh
Skills Learned
Here's a fun little summary of the things I think this project has directly taught me or drastically improved by doing it. Maybe it might be of interest to you to learn them too if you make this project!
- PCB/Design in Fritzing- I could do a bit but now its much easier (no longer needed- see below)
- OpenSCAD- Had never used it before this project. Now it makes total sense (premade items not coding from scratch) and makes customizable files found on Thingiverse WAAAAY easier than their customizer
- Fusion 360- I had ZERO experience and now I have fully customized enclosures I can use for this and ANY other project. I actually look forward to my next 3D designs now
- Inkscape- Free open-source vector graphics program I used to make the 2D enclosure models for people to laser or CNC cut. their own cases (in case they dont have a 3D printer) Awesome program and I was able to copy/paste my way to victory in one day.
- Laser Cutting- I had only used my K40 laser cutter for Covid face shields mainly so I was able to learn how to laser enclosures from both plywood and acrylic. Works great!
- KiCAD- I had never used this and now I have created a functional schematic and PCB from start to finish.
- RF design/Testing- I bought 2 Nano VNAs and learned to use them in order to optimize the antennas for this project. I'm no RF expert but this project has made me learn a TONNE
- HackRF/SDR- I was pretty good with SDR basics but this project let me use the HACKRF and portapack to do testing/validation in the field easily while learning a tonne
- Spectrum Analyzer- Bought a used lab grade unit so I can keep learning more about this wonderful RF world while I further develop this project
- ESP32 Camera Code/use- I've never used or programmed one before. It was a pain at first but now I have the code and settings we can all use for this and future projects.
- Production- I started assembling some kits in case we can use them for funds to produce an AIO board solution and maybe even a product!
- Documentation- This is an ongoing process but finally finding an online resource like diagrams.net to make diagrams- I can finally document things properly YAY!
- Inventory/tracking/BOM & Cost -Learning as I go
- Labeling- I should have bought this Brother 62mm wide labeler years ago- It has been used in all aspects of this project.- LABEL EVERYTHING. In 3 weeks I always forget all details but the label tells me what it is, why I made it, what rev hardware I used- all at a glance. Awesome.
Check out the project logs to how EVERYTHING unfolded :) I hope you enjoy this project as much as I have and make it for yourself. Hit me up for a DIY kit if you like or just to chat.
