This week my new VNA arrived which goes up to ~3 GHz enabling me to finally start testing/optimizing antennas. Although initial testing seemed to working with my existing antennas I suspect with fully optimized/tuned antennas the results will be even better.
Yagi's and Rubber-duck dipoles all ready:
This Nano VNA seems to work great. I will do some tests on lower freq antennas to compare it to my existing VNA which only goes up to ~1 GHz. Since I dont have crazy expensive lab equipment I've learned to make do by cross referencing multiple lower end tools. Everything I read online points to these VNAs working just GREAT for this purpose though. Here is a quick measure across a large portion of the spectrum- you can see the SWR isnt perfect but totally acceptable at 2.4:
Zooming in at our target and calibrating gives a better indication (picture missing)
Testing against some larger (somewhat higher gain) router antennas
I'm pretty happy now that I can work with the antennas properly and I'm finally learning a lot more about RF which is why I do these projects in the first place. Fun
