I needed to get the air unit sorted for the airborne hardware (the ground unit is a lot easier/simpler) so I decided to sort out the enclosure and test fit it this weekend.
Here is the first test version inside the payload bay of the Nano Talon:
The CAD file originated from Thingiverse and the links are in my GitHub repo. The Thingiverse customizer seems to be broken so I downloaded OpenScad and tried my own dimensions:
I was pretty amazed at how easy OpenScad was to work with (small files too). Opened up CURA and sliced/printed on my i3 Mega with no issues
All this will be included in the overview video coming soon. I may need to resize the enclosure once I test the GPS unit (I really want try try to keep the GPS inside the case but probably need to run it to the top of the aircraft).
Progress.
