The weather started out horrible this weekend (kept my test subjects away from the beach) so I decided to tackle the case problem. I really like the state of my 3D printed cases:
But there are 2 fairly serious issues:
- Not everyone has access to a 3D printer
- 3D printed cases would cost a lot for me to ship in kits
Since I really would like to do some kits to possibly bootstrap some funds for the project I really need to solve these. I decided to make a 2D design that can be laser-cut, CNC machined or even cut by hand.
I made this design and modified it in Inkscape to cut on my laser cutter:
It came out pretty great but I had some issues. As usual, I spent the entire weekend iterating the design with dimensional and format tweaks. Cutting them and trying the assembly over and over again.
Getting there:
In the end- I now have SVG and DXF files in my GitHub Repo covering an easy to make case for the air unit. I have also added a readme with assembly instructions just for the cases/enclosures and the various methods of making them HERE
Pretty happy with how it came out!
Being flat 3mm thick material- I can now ship a case with component kits when/if the time comes I actually find some people who actually want to buy a kit 🙂 Both 3mm birch plywood and 3mm acrylic seem to work nicely but the acrylic looks waaaay nicer.
I even went ahead and tackled the ground unit enclosure too. The SVG file was pretty easy since my hardware is the same between air and ground:
It cut out great on the K40:
Then one big happy family was together at last :)
Key takeaway: However long you think it will take to make a simple enclosure- double it... then double it again ;)
Pretty happy with these as the open the door to anyone to make this now without a 3D printer (or with one too)
I ween!
