Solar home metering and monitoring - Residential - Up to 10 KWatt installed. It provides: -- emails with alarms -- a couple of dashboard showing continuously: voltage/current/active power, apparent power, and power factor, both the latest state and historic data aggregated over the last day/week/year.
This is both a software and hardware open source project. The schematics and board layout design for the sensor board, the programs in C and Go, DB schema, and the other configuration files needed are all offered free of charge under a GPLv3 license.
Revitalize your outdoor spaces with our expert jet washing services. Whether it's patios, driveways, or pathways, our skilled team can transform these surfaces, leaving them looking as good as new. https://onegoodhandyman.co.uk/refurbishment/
