Partly because I like the latest version of things and partly because I want more experience with it, I think I'm going to attempt to upgrade U-Boot on this box.
I extracted the dts from a dtb I found online, for the Pronto 3290 (a renamed version of the same hardware):
/dts-v1/;
model = "MPC8541CDS";
compatible = "MPC8541CDS\0MPC85xxCDS";
#address-cells = < 0x01 >;
#size-cells = < 0x01 >;
aliases {
ethernet0 = "/soc8541@e0000000/ethernet@24000";
ethernet1 = "/soc8541@e0000000/ethernet@25000";
serial0 = "/soc8541@e0000000/serial@4500";
serial1 = "/soc8541@e0000000/serial@4600";
pci0 = "/pci@e0008000";
cpus {
#size-cells = < 0x00 >;
PowerPC,8541@0 {
device_type = "cpu";
reg = < 0x00 >;
d-cache-line-size = < 0x20 >;
i-cache-line-size = < 0x20 >;
d-cache-size = < 0x8000 >;
i-cache-size = < 0x8000 >;
timebase-frequency = < 0x00 >;
bus-frequency = < 0x00 >;
clock-frequency = < 0x00 >;
next-level-cache = < 0x01 >;
memory {
device_type = "memory";
reg = < 0x00 0x20000000 >;
soc8541@e0000000 {
device_type = "soc";
compatible = "simple-bus";
ranges = < 0x00 0xe0000000 0x100000 >;
reg = < 0xe0000000 0x1000 >;
memory-controller@2000 {
compatible = "fsl,8541-memory-controller";
reg = < 0x2000 0x1000 >;
interrupt-parent = < 0x02 >;
interrupts = < 0x12 0x02 >;
l2-cache-controller@20000 {
compatible = "fsl,8541-l2-cache-controller";
reg = < 0x20000 0x1000 >;
cache-size = < 0x40000 >;
interrupts = < 0x10 0x02 >;
linux,phandle = < 0x01 >;
i2c@3000 {
cell-index = < 0x00 >;
compatible = "fsl-i2c";
reg = < 0x3000 0x100 >;
interrupts = < 0x2b 0x02 >;
dfsrr;
dma@21300 {
compatible = "fsl,mpc8541-dma\0fsl,eloplus-dma";
reg = < 0x21300 0x04 >;
ranges = < 0x00 0x21100 0x200 >;
dma-channel@0 {
compatible = "fsl,mpc8541-dma-channel\0fsl,eloplus-dma-channel";
reg = < 0x00 0x80 >;
interrupts = < 0x14 0x02 >;
dma-channel@80 {
reg = < 0x80 0x80 >;
cell-index = < 0x01 >;
interrupts = < 0x15 0x02 >;
dma-channel@100 {
reg = < 0x100 0x80 >;
cell-index = < 0x02 >;
interrupts = < 0x16 0x02 >;
dma-channel@180 {
reg = < 0x180 0x80 >;
cell-index = < 0x03 >;
interrupts = < 0x17 0x02 >;
mdio@24520 {
compatible = "fsl,gianfar-mdio";
reg = < 0x24520 0x20 >;
ethernet-phy@0 {
reg = < 0x01 >;
device_type = "ethernet-phy";
linux,phandle = < 0x03 >;
ethernet-phy@1 {
reg = < 0x02 >;
linux,phandle = < 0x04 >;
ethernet@24000 {
device_type = "network";
model = "TSEC";
compatible = "gianfar";
reg = < 0x24000 0x1000 >;
local-mac-address = [ 00 00 00 00 00 00 ];
interrupts = < 0x1d 0x02 0x1e 0x02 0x22 0x02 >;
phy-handle = < 0x03 >;
ethernet@25000 {
model = "TSEC";
reg = < 0x25000 0x1000 >;
interrupts = < 0x23 0x02 0x24 0x02 0x28 0x02 >;
phy-handle = < 0x04 >;
serial@4500 {
device_type = "serial";
compatible = "ns16550";
reg = < 0x4500 0x100 >;
interrupts = < 0x2a 0x02 >;
serial@4600 {
reg = < 0x4600 0x100 >;
crypto@30000 {
compatible = "fsl,sec2.0";
reg = < 0x30000 0x10000 >;
interrupts = < 0x2d 0x02 >;
fsl,num-channels = < 0x04 >;
fsl,channel-fifo-len = < 0x18 >;
fsl,exec-units-mask = < 0x7e >;
fsl,descriptor-types-mask = < 0x1010ebf >;
pic@40000 {
interrupt-controller;
#address-cells = < 0x00 >;
#interrupt-cells = < 0x02 >;
reg = < 0x40000 0x40000 >;
compatible = "chrp,open-pic";
device_type = "open-pic";
linux,phandle = < 0x02 >;
cpm@919c0 {
compatible = "fsl,mpc8541-cpm\0fsl,cpm2";
reg = < 0x919c0 0x30 >;
ranges;
muram@80000 {
ranges = < 0x00 0x80000 0x10000 >;
data@0 {
compatible = "fsl,cpm-muram-data";
reg = < 0x00 0x2000 0x9000 0x1000 >;
brg@919f0 {
compatible = "fsl,mpc8541-brg\0fsl,cpm2-brg\0fsl,cpm-brg";
reg = < 0x919f0 0x10 0x915f0 0x10 >;
pic@90c00 {
interrupts = < 0x2e 0x02 >;
reg = < 0x90c00 0x80 >;
compatible = "fsl,mpc8541-cpm-pic\0fsl,cpm2-pic";
pci@e0008000 {
interrupt-map-mask = < 0x1f800 0x00 0x00 0x07 >;
interrupt-map = < 0x9000 0x00 0x00 0x01 0x02 0x03 0x01 >;
interrupts = < 0x18 0x02 >;
bus-range = < 0x00 0x00 >;
ranges = < 0x2000000 0x00 0x80000000 0x80000000 0x00 0x20000000 0x1000000 0x00 0x00 0xe2000000 0x00 0x100000 >;
clock-frequency = < 0x3f940aa >;
#interrupt-cells = < 0x01 >;
#size-cells = < 0x02 >;
#address-cells = < 0x03 >;
reg = < 0xe0008000 0x1000 >;
compatible = "fsl,mpc8540-pci";
device_type = "pci";
localbus@f0010100 {
#address-cells = < 0x02 >;
compatible = "fsl,mpc8541-localbus\0fsl,pq2-localbus\0simple-bus";
reg = < 0xf0010100 0x40 >;
ranges = < 0x00 0x00 0xfe000000 0x2000000 0x01 0x00 0xf0000000 0x20000 0x02 0x00 0xf0010000 0x10000 0x03 0x00 0xf2000000 0x100000 0x04 0x00 0xe0000000 0x02 >;
cfcard@1 {
compatible = "qci-ide";
device_type = "ide";
reg = < 0x01 0x00 0x20000 0x04 0x00 0x100000 >;
ioport_shift = < 0x01 >;
reg-shift = < 0x01 >;
interrupts = < 0x02 0x02 >;
Scanning the /proc/device-tree on the running switch yields
# ls -R /proc/device-tree/ /proc/device-tree/: #address-cells chosen linux,phandle name #size-cells compatible memory soc8541@e0000000 aliases cpus model /proc/device-tree/aliases: name serial0 serial1 /proc/device-tree/chosen: bootargs linux,initrd-start name linux,initrd-end linux,stdout-path /proc/device-tree/cpus: #address-cells #size-cells name #cpus PowerPC,8541@0 /proc/device-tree/cpus/PowerPC,8541@0: 32-bit device_type reg bus-frequency linux,phandle timebase-frequency clock-frequency name /proc/device-tree/memory: device_type linux,phandle name reg /proc/device-tree/soc8541@e0000000: #address-cells ethernet@24000 name serial@4500 #interrupt-cells ethernet@25000 pci@8000 serial@4600 #size-cells i2c@3000 pic@40000 bus-frequency linux,phandle ranges device_type mdio@24520 reg /proc/device-tree/soc8541@e0000000/ethernet@24000: #address-cells device_type linux,phandle name #size-cells interrupt-parent local-mac-address phy-handle compatible interrupts model reg /proc/device-tree/soc8541@e0000000/ethernet@25000: #address-cells device_type linux,phandle name #size-cells interrupt-parent local-mac-address phy-handle compatible interrupts model reg /proc/device-tree/soc8541@e0000000/i2c@3000: compatible dfsrr interrupts name device_type interrupt-parent linux,phandle reg /proc/device-tree/soc8541@e0000000/mdio@24520: #address-cells device_type linux,phandle #size-cells ethernet-phy@1 name compatible ethernet-phy@2 reg /proc/device-tree/soc8541@e0000000/mdio@24520/ethernet-phy@1: device_type linux,phandle name reg /proc/device-tree/soc8541@e0000000/mdio@24520/ethernet-phy@2: device_type linux,phandle name reg /proc/device-tree/soc8541@e0000000/pci@8000: #address-cells compatible interrupts #interrupt-cells device_type linux,phandle #size-cells interrupt-map name bus-range interrupt-map-mask ranges clock-frequency interrupt-parent reg /proc/device-tree/soc8541@e0000000/pic@40000: #address-cells clock-frequency linux,phandle #interrupt-cells compatible name big-endian device_type reg built-in interrupt-controller /proc/device-tree/soc8541@e0000000/serial@4500: clock-frequency device_type interrupts name compatible interrupt-parent linux,phandle reg /proc/device-tree/soc8541@e0000000/serial@4600: clock-frequency device_type interrupts name compatible interrupt-parent linux,phandle reg
Parsing deeper than this is difficult, as the linux build on the system lacks a lot of essential tools like hexdump that would allow me to read the raw values on the tree.
Of specific note is the root node /proc/device-tree/compatible, which is LB4M.
It's possible this system is running a contorted LB4M firmware, but everywhere else it identifies as a LB9A. It would also be a very odd change, since the LB4M apparently ran a VXWorks kernel under the hood, with a few hardware differences as well. One quirk supports the possibility; when booting I get an error relating to connecting the Ethernet PHY and the two front panel OOB management ports don't work. I can ping out on them in U-Boot, so I know the hardware is good.
This software is definitely not stock, as it has overwritten the default recovery tools as well. I almost want to buy another of these switches from another vendor to see if I can get a different draw on firmware.
