A temperature regulated surface for fluid warming made of 3D printed and easily accessible parts.
There are a few main different styles of fluid warmers:
Pros:
Cons:
Pros:
Cons:
Pros:
Cons:
In terms of user appeal the In-line heater is likely the most desirable as it is the easiest to use and takes up the least space. The challenge here though isn't to create the best new product, but to make one that is open source, easy and quick to manufacture, cheap, and reliable. The idea I have for my project sacrifices ease of use to maximize ease of production and operation in the scarcest conditions.
Fluid warmers are important devices in medical facilities, but they can be difficult to get in developing areas. There is a high cost for this equipment (often thousands of dollars), and it can take a long time to obtain or replace. We’ve also seen that global issues like COVID-19 can cause serious supply chain issues on custom equipment.
The solution to these two hurdles would be a completely open source device that can be assembled by nearly anyone with easy to obtain and standard components. Any custom parts would ideally be 3D printed. This would allow the device to be largely built and assembled in the country it is to be used in. The device should be easy to assemble, without requiring any special skills or advanced tools (soldering, PCB production).
Aesthetics, user interface, and features will likely be simple in order to best accomplish the above requirements.
To reiterate, the most important metrics would be:
Thanks! In progress of being 3D printed as we speak actually. Made some design changes that will hopefully work well and simplify things. ABS is being painful to print though as I keep getting small gaps show up as lower layers of the ABS are cooling (even with a 110 degree C heated bed). Not the worst thing ever as I can seal those up, but annoying.
Hello! an Exciting project I see, are you going to make a prototype?
