Upgrades to a balance bot - and keeping a 6 year old entertained.
Elegoo balance hat.stlA sort of upturned sombrero type thing which round things can yammer about in. Adds mass high up which increases stability and reduces period of oscillation.Standard Tesselated Geometry - 889.24 kB - 06/04/2020 at 19:22 |
Elegoo balance arms.stlWhy did it have only 1 arm? A pair of arms is clearly better. This makes it possible to get back up from either a backward or forward fall. In fact getting up is easier as 2 arms are more balanced - and I cheated a bit by extending them slightly to lessen the angle of tilt when leaning on one.Standard Tesselated Geometry - 249.59 kB - 06/04/2020 at 19:22 |
The little robot is quite interesting. Probably more so for a budding teen who can get to grips with it all than a 6 year old and her father who's some sort of engineer already. But this meets in the middle.
The first thing to sort out was to give it a silly hat. Something that between a hat and a bowl seemed a good place to start (as a bowl just sitting on it's head with a Nerf ball in it worked well).
Then the arms - it only had 1. A pair seemed sensible, but modified to allow marbles to skitter about in them.
Now it's more fun to look at and stack stuff on, but the PID could do with a tweak. Well, it could have done with a tweak before increasing it's moment of inertia. That's for next time.
