It seems that my workhorse distro prefers chronyd to ntpd. I was wondering why my ntpd was exiting after a day or two of operation. It turns out that this was due to a clash with chronyd. After reading an article on the Internet I have accepted my distro's judgement that chronyd is an improvement on ntpd, so I have configured it to use my GNSS server in the same way, by adding a server line. Here's the output of chronyc sources -v. You can see there is a wealth of detail.
# chronyc sources -v
210 Number of sources = 17
.-- Source mode '^' = server, '=' = peer, '#' = local clock.
/ .- Source state '*' = current synced, '+' = combined , '-' = not combined,
| / '?' = unreachable, 'x' = time may be in error, '~' = time too variable.
|| .- xxxx [ yyyy ] +/- zzzz
|| Reachability register (octal) -. | xxxx = adjusted offset,
|| Log2(Polling interval) --. | | yyyy = measured offset,
|| \ | | zzzz = estimated error.
MS Name/IP address Stratum Poll Reach LastRx Last sample
^- ntp1.ds.network 4 6 377 32 -3854us[-3670us] +/- 37ms
^- any.time.nl 2 6 377 36 -2552us[-2369us] +/- 56ms
^- ec2-13-55-50-68.ap-south> 3 6 377 30 +3660us[+3660us] +/- 109ms
^- ntp3.ds.network 4 6 377 35 -3247us[-3064us] +/- 36ms
^- dns01.ntl02.privatecloud> 2 6 377 33 -799us[ -615us] +/- 47ms
^- cosima.470n.act.tsgnl.co 2 6 377 34 -1030us[ -846us] +/- 61ms
^+ time.cloudflare.com 3 6 377 33 -1061us[ -877us] +/- 15ms
^- 220-158-215-20.broadband> 2 6 377 32 +9851us[ +10ms] +/- 38ms
^- ntp2.ds.network 4 6 377 32 -1467us[-1283us] +/- 37ms
^- dns01.syd01.privatecloud> 2 6 377 32 -3567us[-3382us] +/- 42ms
^- mika.470n.act.tsgnl.co 2 6 377 31 -1762us[-1762us] +/- 51ms
^- pauseq4vntp1.datamossa.io 2 6 377 30 -1399us[-1399us] +/- 42ms
^+ time.cloudflare.com 3 6 377 35 -1016us[ -833us] +/- 15ms
^+ bitburger.simonrumble.com 1 6 377 30 +676us[ +676us] +/- 13ms
^- 123.50.146.78 2 6 337 34 -899us[ -716us] +/- 172ms
^- pauseq4vntp2.datamossa.io 2 6 377 35 -1745us[-1562us] +/- 38ms
^* rpi1.local 1 6 377 31 +354us[ +538us] +/- 6065us
I might be able to reduce that 6 ms estimated error by tuning.
