PCB design was started.
The dimensions will be just below 10 x 10 cm. DIN 41612 connector at one side. All SMD devices.
4 layer pcb.
The upper part of the pcb is now routed for the most part. In the lower part you see the ratsnest of connections that are waiting to get routed.
nice looking layout!
