Now that I know how DACs and OpAmps can be used for creating the right signal for the galvo drivers the next thing will be processing the Step/Dir signal from a machine controller (Arduino CNCShield, Ramps and so on).
For that I want to use at first just an Arduino UNO or NANO to do it in the easiest possible way.
If it turns out that more speed is needed, I can later switch to a more capable microcontroller.
I tried to read step/dir pulses created by an Arduino UNO with another Arduino UNO and it worked so far with up to 60kHz.
For testing the output I tried to drive a servo with the received Step/Dir signal at low frequency.
Reading Step/Dir and sending it to the DAC works, too.
The next thing will be testing with a real Step/Dir signal from a cnc or 3d printer controller and building a cleaner test setup.
