This model printed well at 19 hours long. We will work to get print times down as the parts are made thinner and frame thickness is reduced. Frame material thickness is 5-6 mm here. Please welcome our handsome model as he shows how closely the mask fits to the face without pressing or an adaptable seal. The cheek curvature and nose bridge gaps need to be adjusted and then we will start working on a seal.
Josh Starnes
