These are the first 5 mask sizing frames. These are a bit rough and need to be hit with some sandpaper to remove the buggers. This is largely because I printed at .2mm and higher print speed with random start and stop points selected in Simplify 3D. The 5th size appears to fit my mother perfect.
Josh Starnes
