The last few months I mainly worked on creating a custom script interpreter for 'syncBlink'.
All available script interpreters I used and tested had some limitations or I was not able to get it run on the ESP8266. Thats why I decided to write an own interpreter, because why not. At the same time I created a mod-less version of syncBlink which also exposes a web application. The web application provides the following features at the moment:
- Switching Mods
- Setting WiFi connection
- Mod Editor
