In this project, I used an lcd to display the distance of an object measured by an ultrasonic sensor.
ino - 872.00 bytes - 06/10/2020 at 12:17
JPEG Image - 179.64 kB - 06/10/2020 at 11:33
JPEG Image - 112.10 kB - 06/10/2020 at 11:33
View all 6 components
connect the ground and 5v from arduino to breadboard
Set up the ultrasonic sensor
VCC -5V
TRIG -PIN 13
ECHO -11
GND -GROUND
set up the potentiometer and lcd using the info provided in files
View all instructions
Eventually you may want to go wireless with NodeMCU. Less expensive and far more powerful. Learn some HTML and monitor and control from a web page hosted on the device. Program with Arduino IDE. Upload program wirelessly.
https://sites.google.com/site/nodemcu12e/
oh wow. Great
hIOTron
Moreira
Rasank Patro
electronicsworkshops
Yes, delete it Cancel
You are about to report the project "Beginning_Arduino", please tell us the reason.
