"Nerdiskerator" = NERdiys DISK genERATOR -> The 3D printed disk generator
A project log for WinDIY - HAWT Wind turbine
Mostly 3D printed HAWT windturbine incl. 3D printed disk-generator and brake system.
fabianFabian 06/10/2020 at 18:350 Comments
I decided to document the "Nerdiskerator" in a separate project log. I think that way you can keep a better overview of the respective projects. :)
Please see the Project log here: https://hackaday.io/project/172445-nerdiskerator-a-3d-printed-disk-generator
At the same time (or whenever I got stuck with the wing), I had already started developing the associated disk generator. I wrapped it around the neodymium magnets that I already had at home. With a length of 13mm and a diameter of 13mm (cylindrical shape), these do not actually correspond to the typical magnetic shape for disk generators. But back then I still thought that this would be a small weekend project for which I would not need to buy extra magnets. : D
For the first design, I only fixed the magnets in the rotor with screws. For this purpose, the rotor did not get all twelve but only four coils. So at least I had already set up a test phase.
A first test with the cordless screwdriver already showed an electrical output power of ~ 23W. There is certainly more here. But I think that the cordless screwdriver can no longer deliver mechanical power. Here, the cordless screwdriver is the limiting factor. :)
