In the last few days I have been working on the first drafts for the anemometer for WinDIY_2 (project log: https://hackaday.io/project/179999-windiy2-horizontal-axis-wind-turbine). You can find the first information about this in the following project log: https://hackaday.io/project/180202-anemosens-sla-printed-anemometer
Since I've always wanted to build an anemometer anyway to be able to collect wind data for my weather station, I built the sensor modular so that it can also be used in other situations (e.g. a weather station).
I tried to make the wind sensor as compact as possible. The sensor electronics will be built into the 27mm thick shaft. Later I want to build an adapter board so that the wind data can then also be read via RS485 or USB. :)
