Documentation of the Aruna library is now hosted on Codedocs.xyz. The documentation gets automatically updated after every push! They unfortunately don't support call graphs, so you will have to generate the documentation locally if you want to easily see how everything gets called. I might reupload the documentation somewhere else at some point that does support `dot`.
I also added the GNU GPLv3 license for all the repositories in the project.
Noeƫl Moeskops
