December 11, 2022 - Yup, sounds like a weight reduction goal and this is the first phase. My wall sized panels were.......Well....... wall sized and taking up too much space. This first step is wiring the State Machine onto some perf board and once that is de-bugged I will do the same for the ALU. The following is the major parts layout for the SM.
Dr. Cockroach
