941-1792-ND PACSR12042S AC/DC CONVERTER 12V 504W | 1 | Immediate | 187.87000 | $187.87 | |
2 | 1189-2033-ND 450VXH220MEFCSN25X35 CAP ALUM 220UF 20% 450V SNAP | 3 | Immediate | 3.86000 | $11.58 |
3 | 490-9555-1-ND DE2E3KY222MN2AM01F CAP CER 2200PF 250VAC RADIAL | 1 | Immediate | 0.46000 | $0.46 |
4 | P122323CT-ND EEU-FS1C821LB CAP ALUM 820UF 20% 16V THRU HOLE | 6 | Immediate | 0.66000 | $3.96 |
5 | 490-9555-1-ND DE2E3KY222MN2AM01F CAP CER 2200PF 250VAC RADIAL | 1 | Immediate | 0.46000 | $0.46 |
6 | 1189-2033-ND 450VXH220MEFCSN25X35 CAP ALUM 220UF 20% 450V SNAP | 1 | Immediate | 3.86000 | $3.86 |
7 | 490-9531-1-ND DE2B3KY101KN2AM01F CAP CER 100PF 250VAC RADIAL | 3 | Immediate | 0.41000 | $1.23 |
8 | 490-9561-1-ND DE2E3KY472MN2AM01F CAP CER 4700PF 250VAC RADIAL | 10 | Immediate | 0.39600 | $3.96 |
9 | 1572-1784-ND MPX104K305D CAP FILM 0.1UF 10% 305VAC RAD | 2 | Immediate | 0.41000 | $0.82 |
10 | P14783-ND ECQ-UAAF474M CAP FILM 0.47UF 20% 275VAC RAD | 3 | Immediate | 0.64000 | $1.92 |
11 | 490-9463-ND DE2E3KY152MA3BM02F CAP CER 1500PF 250VAC RADIAL | 2 | Immediate | 0.45000 | $0.90 |
12 | RNV14FAL820KCT-ND RNV14FAL820K RES MF HV .25W 820K OHM 1% AXIAL | 3 | Immediate | 0.26000 | $0.78 |
13 | 553-3963-ND PH9455.705NL CMC 6.5MH 9A 2LN 6.4 KOHM TH | 2 | Immediate | 7.61000 | $15.22 |
