I had to balance and adjust 4-5 times to get the drone to sit label balanced on the tips of the motor shafts. The power supply rack needed to slide forward over an inch as well as the 5G dish. Zip ties on the front and back of the rails keep the power supplies in the balanced position. Any changes in the future require this balance to be adjusted to keep the power consumption down for extended hovering.
Josh Starnes
