Thermistor with arduino to measure temperature
It is an easy way to measure the exact temperature with a thermistor.
In this project, we have come up with thermistor interfacing with Arduino to measure temperature and display it on the LCD.
About Project
Thermistor
The important segment in this circuit is Thermistor, which has been utilized to recognize the rise in temperature. The thermistor is temperature sensitive resistor, whose resistance modifies as per the temperature.
There are two different types of thermistor NTC and PTC, we have used as an NTC type thermistor. NTC thermistor is a resistor whose resistance diminishes as arise in temperature while in PTC it will improve the resistance as arise in temperature.
Calculating Temperature using Thermistor
Vout= (Vin * Rt) / (R + Rt)
 Rt value will be:
 Rt = R (Vin/Vout) – 1
 Here, Rt will be the resistance of the thermistor and the value of R is 10k ohm. Calculation of Temperature from the thermistor resistance
 T = 1 / (A + Bln(Rt) + Cln (Rt)3 ) Where, A, B and C are the constants,
 So, for estimating the temperature we require the value of thermistor resistance only.
  • 1 × NTC thermistor 10k
  • 1 × Arduino UNO & Genuino UNO
  • 1 × Resistor 10k ohm
  • 1 × LCD - 16x2
  • 1 × Connecting wires
  • 1
    Run a Program
    #include
    #include "LiquidCrystal.h"
    LiquidCrystal lcd(44,46,40,52,50,48);
    float A = 1.009249522e-03, B = 2.378405444e-04, C = 2.019202697e-07;
    float T,logRt,Tf,Tc;
    float Thermistor(int Vo) {
    logRt = log(10000.0*((1024.0/Vo-1)));
    T = (1.0 / (A + B*logRt + C*logRt*logRt*logRt)); // We get the temperature value in Kelvin from this Stein-Hart equation
    Tc = T - 273.15; // Convert Kelvin to Celcius
    Tf = (Tc * 1.8) + 32.0; // Convert Kelvin to Fahrenheit
    return T;
    void setup(){
    lcd.begin(16,2);
    lcd.clear();
    void loop()
    lcd.setCursor(0,0);
    lcd.print("Temp:");
    lcd.print((Thermistor(analogRead(0))));
    lcd.print("k ");
    lcd.setCursor(0,1);
    lcd.print((Tc));
    lcd.print(" C ;");
    lcd.setCursor(9,1);
    lcd.print((Tf));
    lcd.print(" F");
    delay(800);
View all instructions
