A gaming handheld device based on STM32 that can run Makecode Arcade games.
Schematic_MakeCode Arcade Hardware copy_20200120094129.pdfSchematicsAdobe Portable Document Format - 155.71 kB - 06/17/2020 at 10:26 |
Gerber_Makecode PCB - STM32F411RET6_20200120094259.zipPCB filesZip Archive - 182.57 kB - 06/17/2020 at 10:27 |
bootloader-fromMake.binBootloaderoctet-stream - 32.00 kB - 06/17/2020 at 11:41 |
ARCADE-F4-MyTetrisClone.uf2Tetris gameuf2 - 709.00 kB - 06/17/2020 at 10:27 |
Top.stl3D printable files - housing top partsla - 171.18 kB - 06/17/2020 at 10:29 |
Use the gerber files to order the PCB from the company of your choice. You'll also find the schematics that will allow you to modify some aspects and route your own PCB if wishes.
You'll find the BOM that you can use to make the order. Some of the components are pretty small and will require some skills.
Connect the board to a PC using a STlink in order to flash the MCU with the bootloader file.
