I've submitted the revised layout to OSH Park for fabrication. The new boards should arrive in a few weeks.
![](https://cdn.hackaday.io/images/7528611593630782380.png)
The only change is to the PPS polarity detection which required an additional resistor and diode to make the PPS timer reset asymmetric.
A project log for GPSDO Slave Clock
BPSK receiver for GPSDO timing output signal.
